16 years agoSRAM use & capabilities
Hi y'all, Here's the problem - I am building a counting device and I'm running out of storage room on the DE2. I am currently using registers and would like to use the SRAM chip. 1. d...
16 years agoi dont say something about the nios, you muss write interface to the memory in the verilog, this sram is asynchronous, so sram dont need clock, so your question is irrelevant, important value is tAA, which is Address Access Time, this sram has only 16bit data port, so you need read low word and high word, its 2xtAA, but it depends also on your code in the verilog (additional delays in your system)
i think its clear
