16 years agoSRAM 160MHz, impedance matching
Hello, In my board I have one SRAM directly connected to a FPGA Cyclone 2. I am working at 160MHz. But sometimes I have an strange behavior when reading the SRAM. I am sure is something ab...
16 years agoHow can you determine this without watching the waveforms?
R/ After test and simulate almost all the design, I suspected it was something with the impedances. So, I played a little bit with the assignation of the pins, and the resultats of the output change. For example if I change the assignation of the LSB and the MSB bit of the DATA BUS of the SRAM, in the output I can see drastical changes. DABG
