16 years agoSRAM 160MHz, impedance matching
Hello, In my board I have one SRAM directly connected to a FPGA Cyclone 2. I am working at 160MHz. But sometimes I have an strange behavior when reading the SRAM. I am sure is something ab...
16 years ago --- Quote Start --- but in the output there are more noise --- Quote End --- How can you determine this without watching the waveforms? You also didn't tell about the observed problems. Apart from Cyclone III I/O constraints, there can be no real impedance matching with the involved standards. You can at best achieve a source sided series termination of the address and control signals, but it's threatened by the SRAM input capacitance. Any achievable termination will be a compromise. With the data lines, you would need source sided termination for both directions. I guess, you also don't know about the exact trace impedance in your design, and most likely coupling between signals is an issue. In this case, how to check for correct operation without a measurement? I don't know. My normal procedure would be to check the waveform and try different current strength settings. I can hardly imagine, that you don't have at least a few signals that can be probed. Altera has set a limitation to selectable I/O settings at high VCCIO (3.3 and 3V, if I remember right). Before taking 50 ohm termination into your head, you should check the behaviour with the available settings. Small PCB traces have rather 70 than 50 ohm impedance. If the observed waveforms actually indicate too high impedance, you should report.
