16 years agoSRAM 160MHz, impedance matching
Hello, In my board I have one SRAM directly connected to a FPGA Cyclone 2. I am working at 160MHz. But sometimes I have an strange behavior when reading the SRAM. I am sure is something ab...
16 years agoCurrent strength can be comfortably set in the Quartus Pin Planner. You have to add a "current strength" column in the pin list by the "Customize Columns" function in the context menu.
Generally, it's recommended to check the actual signal waveforms at the load with a low capacitance probe.
