14 years ago
SR flipflop problem
Hi. I made a SR ff code, and compile is done well.
but when i simulated this code.... It looks different from what i made.
(p.s please don't say that use the D flipflip!! I just want to know what the problem is
in my code!! Thanks!)
this is code
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY flip is
PORT(
s, r : in std_logic;
q, nq : inout std_logic);
end flip;
ARCHITECTURE arc of flip is
begin
process(q,s,r)
begin
if(s='1' and r ='1') then
q<='1';
nq<='1';
else
nq<= s xor q;
q<= r xor nq;
end if;
end process;
end arc;
and this is simulation image!!
http://image.kilho.net/?pk=1013878&from=web
(p.s is there anyone who know how to insert the image in here?)
    I think you are talking about the basic SR FF. This was done by connecting two nor gates in feedback (or two nand gates). So all you need is a combinatorial circuit:
    q <= r nor qn;
    qn <= s nor q;
    s & r should be either 00,01,10 but not 11 hence the further development to D where S &R inputs were replaced by one input D that acts as S and internally inverted to act as R.
    You may need to insert delays if your output vibrates.
    1. why are q and nq inouts? they just want to be out
    2. you're missing nq from the sensitivity list.
    3. this is not a flip-flop, there is no clock.
    4. shouldnt reset have preference over set?
