14 years agoSR flipflop problem
Hi. I made a SR ff code, and compile is done well. but when i simulated this code.... It looks different from what i made. (p.s please don't say that use the D flipflip!! I just want to know wha...
14 years agoI think you are talking about the basic SR FF. This was done by connecting two nor gates in feedback (or two nand gates). So all you need is a combinatorial circuit:
q <= r nor qn; qn <= s nor q; s & r should be either 00,01,10 but not 11 hence the further development to D where S &R inputs were replaced by one input D that acts as S and internally inverted to act as R. You may need to insert delays if your output vibrates.
