13 years ago
SPI with DMA is not working?
Hi, everyone
I am using SPI Master Core on FPGA to transmit data to SPI slave (offboard device). I want to use DMA to free my NIOS for other tasks during SPI data transfer. My Idea is
NIOS - DMA - SPI(master) <-> SPI (slave / extern device)
I can not understand, how can it work.
SPI master core send and receive data at the same time. After sending, e.g, 8 bits data I also have to read the 8 bits data in RXdata register which resets RRDY bit in status register. Otherwise I will get a ROE (Receive overrun error), If I send another 8 bits data.
If I use DMA to send, e.g., 20 bytes data continiously without reading any data from SPI Rxdata, I will definetely get error and Sending will not be successful.
Has someboby really used SPI with DMA to send data? How can it work?
Thanks a lot!
    Would have been nice(r) if you gave the actual MPU part-number.
    SPI interfaces differ from device to device, so I wrote a general SPI-master interface handling some of the differences. I recently wrapped this in a MM-Slave block.
    I have no idea if modifying the Altera supplied SPI module is straightforward. (They are in Verilog, and I do VHDL ...). A lot of the Qsys building blocks are NIOS II oriented and thus driven by software. This complicates things now and then.
    It is interfaces on LCD controller which is called SSD1325.
    MPU Interface selection
    SSD1325 MCU interface consist of 8 data pins and 5 control pins. The pin assignment at different interface mode is summarized in Table 6. Different MCU mode can be set by hardware selection on
    BS[2:0] pins (please refer to Table 5 for BS[2:0] setting).
    Table 6 : MCU interface assignment under different bus interface mode
    Pin Name D7 D6 D5 D4 D3 D2 D1 D0 E R/W# CS# D/C# RES#
    parallel interface
    8-bit 8080 D[7:0] RD# WR# CS# D/C# RES#
    8-bit 6800 D[7:0] E R/W# CS# D/C# RES#
    or
    SPI SDIN SCLK Tie LOW CS# D/C# RES#
    The receiving device is clear to me now.
    I (re-)checked the documentation on the SPI-core in the Embedded Peripherals Guide, and it is effectively meant to be driven by software. The module has no waitrequest signal to hold of successive writes (read) until each SPI transfer has finished.
    I found another issue.
    just for testing I shut off RX path and use DMA to stream 5 bytes data to SPI TX holding register. but no success!
    I could only send 2 bytes and then I got a TOE.
    SPI has signal "readyfordata" als flow controll. But I can not find any signal somehow like that on DMA write master, which leads DMA send the 5 data to SPI without considering if SPI is ready or not.
    How does DMA controll data flows?
    Avalon MM master : waitrequest
    Avalon MM slave: dataavailable, endofpacket & readyfordata
    How can it work? Thanks
    --- Quote Start ---
    --- Quote End ---
    It doesn't. The MM interface hasn't got a waitrequest to hold the DMA off, effectively resulting in a TXOverrun at the second write.
    The dataavailable and readyfordata are internally connected only and read as 'status' signals by a Nios II CPU.
    Maybe you can try inverting the readyfordata and use that as a waitrequest.
    --- Quote Start ---
    --- Quote End ---
    In V file I found
    // Ready to accept streaming data.
    assign readyfordata = TRDY;
    the signal readyfordata indicates if Transmit ready bit is set. Inverting the readyfordata/TRDY for every write prevents my NIOS from doing other tasks. Or do U mean I should change hardware to do it? thanks
    Of course you would have to modify the logic source and create a new module.
    If you want to access that module both from the Nios II CPU and from a DMA controller, things get complicated. That complexity is now handled by the Qsys fabric that 'separates' the two masters accessing the same slave. If you hack the SPI source into an output-only SPI with waitrequest you should be able to connect both the CPU and the DMA controller, but you will have to re-write the software driver as well.
    I am still wondering cause I found the following sentence in document ug_embedded_ip. So I have to understand there is a bug in document?
    actually UART has the same interface as SPI for data transfer. So can I neither use DMA to stream data to UART?
    "The SPI core can be used in conjunction with
    a DMA controller with flow control to automate continuous data transfers between, for example, the SPI core and memory."
    I actually build a minimal system in Qsys and generated the system to inspect the code. I exported both the MM Slave interface and the SPI conduit.
    I played around with the checkboxes etc. but the HDL example didn't change ... no waitrequetst signal showed up.
    So I think it doesn't work without some extra work.
