14 years agoSPI with DMA is not working?
Hi, everyone I am using SPI Master Core on FPGA to transmit data to SPI slave (offboard device). I want to use DMA to free my NIOS for other tasks during SPI data transfer. My Idea is NIOS...
14 years agoI am still wondering cause I found the following sentence in document ug_embedded_ip. So I have to understand there is a bug in document?
actually UART has the same interface as SPI for data transfer. So can I neither use DMA to stream data to UART? "The SPI core can be used in conjunction with a DMA controller with flow control to automate continuous data transfers between, for example, the SPI core and memory."
