14 years agoSPI with DMA is not working?
Hi, everyone I am using SPI Master Core on FPGA to transmit data to SPI slave (offboard device). I want to use DMA to free my NIOS for other tasks during SPI data transfer. My Idea is NIOS...
14 years agoIt is interfaces on LCD controller which is called SSD1325.
--------------------------------------- MPU Interface selection SSD1325 MCU interface consist of 8 data pins and 5 control pins. The pin assignment at different interface mode is summarized in Table 6. Different MCU mode can be set by hardware selection on BS[2:0] pins (please refer to Table 5 for BS[2:0] setting). Table 6 : MCU interface assignment under different bus interface mode Pin Name D7 D6 D5 D4 D3 D2 D1 D0 E R/W# CS# D/C# RES# parallel interface 8-bit 8080 D[7:0] RD# WR# CS# D/C# RES# 8-bit 6800 D[7:0] E R/W# CS# D/C# RES# or SPI SDIN SCLK Tie LOW CS# D/C# RES#
