17 years agospi implementation using vhdl
hi
any one can send vhdl code for spi, regards mk3 Replies
SOPC builder is a tool that can be used to connect components together, mainly used to create systems around the Nios II processor.
If you don't plan to interface your SPI bus with a CPU, you can write your own component in HDL. The SPI protocol it is quite straightforward. - Altera_Forum
hi Daixiwen
thanks for your valuable reply,still i have some more doubts because i am very new to this, 1.what is sopc builder? 2. how to use that master and slave components in sopc builder ? regards krishnam raju --- Quote Start --- There is a standard SPI master component in SOPC builder. If you are looking for something else, you'll have to be more specific about your needs. --- Quote End --- - Altera_Forum
