17 years agospi implementation using vhdl
hi any one can send vhdl code for spi, regards mk
17 years agoSOPC builder is a tool that can be used to connect components together, mainly used to create systems around the Nios II processor.
If you don't plan to interface your SPI bus with a CPU, you can write your own component in HDL. The SPI protocol it is quite straightforward.
