16 years agospeed grade
Hi, if i'm using CYCLONE III EP3C40F484C6 - that means that its speed grade is 6 . right? Thanks, Fina.
16 years ago --- Quote Start --- Thanks a lot for your answers :) :) :) how can i know device max speed? --- Quote End --- Hi, sorry, I was not exact enough in my post. The timing for e.g. PLL's, I/O, I/O standards could be used to decide which speed grade do you need for your application. What I mean in my first post is was that the internal clock speed depends on your design. When you look into the datasheet you find e.g. a number for the clocktree speed ( C8 402 MHz). This doesn't mean that your design could run at this speed. Sorry for any confusion. Kind regards GPK
