16 years ago
speed grade
if i'm using CYCLONE III EP3C40F484C6 - that means that its speed grade is 6 . right?
Fina.
    --- Quote Start ---
    Thanks a lot for your answers :) :) :)
    how can i know device max speed?
    --- Quote End ---
    sorry, I was not exact enough in my post. The timing for e.g. PLL's, I/O, I/O standards could be used to decide which speed grade do you need for your application. What I mean in my first post is was that the internal clock speed depends on your design. When you look into the datasheet you find e.g. a number for the clocktree speed ( C8 402 MHz). This doesn't mean that your design could run at this speed.
    Sorry for any confusion.
    Kind regards
    GPK
    --- Quote Start ---
    Fina.
    --- Quote End ---
    yes that's right. Keep in mind that it is not an exact indication of the max speed of the FPGA.
    Kind regards
    GPK
