Source Synchronous between 2 Altera FPGA
- 3 years ago
Hi.
1) Should be good enough for DIB interface. Probably needs to take the DIB Latency into consideration as well check this https://www.intel.com/content/www/us/en/docs/programmable/683142/20-2-19-3-0/timing-transfer-for-bypass-mode.html and this https://www.intel.com/content/www/us/en/docs/programmable/683142/20-2-19-3-0/latency.html
2) Yes, Intel recommendation in "Source-Synchronous" methodology took into account the IO delay for the values of the T-hold / T-setup only for the register. External IO and Cable /PCB connection between the FPGA probably will need to take into account the extra latency.
Sheng
Hi.
Sheng
