11 years ago
sorter in vhdl
hi every one
i want avhdl code to sort integer input ascending
if i have an array such as
1,8,9,7,2
the out put will be such as
1,2,7,8,9
i search a lot but didn't find any code that helping me
thanks .
    you know , you are a great man
    i want to thank you very much for helping me
    but, why the first input becoming the first output whereas should be the last output ???
    I gave you a Guide and left details for you to manage. It is not in your interest to hand you a finished work.
    However, this time I will correct my latency issue, see code below).
    You can do a further modification if you want to get rid of zero data and interrupted read by reading into two further rams.
    one for code and one for duration, both rams addressed by counter that increments only if non zero data arrives... then finally read out both rams from 0 to count value.
     library ieee;
        use ieee.std_logic_1164.all;
        use IEEE.numeric_std.all;
        entity bubblesort is
        port(
            clk      : in std_logic;
            we       : in std_logic := '1';
            trigraph : in std_logic_vector(7 downto 0) := x"0F";
            duration : in integer range 0 to 1023 := 5;
            read     : in std_logic := '0';
            dout     : out std_logic_vector(7 downto 0)
        end entity;
        architecture rtl of bubblesort is
        signal address, rd_addr : integer range 0 to 1023 := 0;
        signal trigraph_d : std_logic_vector(7 downto 0);
        signal we_d : std_logic := '0';
        type mem is array(0 to 1023) of std_logic_vector(7 downto 0);
        signal ram : mem := ((others=> (others=>'0')));
        begin
        --infer ram
        process(clk)
        begin
        if(rising_edge(clk)) then
           dout <= ram(address);
           if(we_d = '1') then
              ram(address) <= trigraph_d;
           end if;
        end if;
        end process;
        process(clk)
        begin
        if rising_edge(clk) then
          we_d <= we;
          trigraph_d <= trigraph;
          if read = '1' then
            if rd_addr < 1023 then
              rd_addr <= rd_addr + 1;
            end if;
          end if;
          if read = '0' then
            address <= duration;
          else
            address <= rd_addr;
          end if;
        end if;
        end process;
        end rtl;
    --- Quote Start ---
    i try to modify the code it is as you suggest kaz
     library ieee;
        port(
            clk      : in std_logic;
            code     : out std_logic_vector(7 downto 0)
        end entity;
        signal trigraph_d,dout  : std_logic_vector(7 downto 0);
         signal N     : integer   := 0;
        begin
        --infer ram
        process(clk)
        begin
           if(we_d = '1') then
           end if;
        end if;
        end process;
        process(clk)
        begin
          we_d <= we;
          if read = '1' then
            end if;
          end if;
          if read = '0' then
          else
            address <= rd_addr;
          end if;
        end if;
        end process;
         ------discard zero values
         process(read,dout)
         begin
         if  read = '1' then
         if dout /= "00000000" then
              N <= N + 1;
              code <= dout;
              end if;
              end if;
              end process;
        end rtl;
    or that modification is right
    i hope you advise me
    library ieee;
        port(
            clk      : in std_logic;
        end entity;
    	 signal dout_buf : std_logic_vector(7 downto 0) := x"ff";
        begin
        --infer ram
        process(clk)
        begin
           if(we_d = '1') then
           end if;
        end if;
        end process;
        process(clk)
        begin
          we_d <= we;
          if read = '1' then
            end if;
          end if;
          if read = '0' then
          else
            address <= rd_addr;
          end if;
        end if;
        end process;
    	 --discard zeros values
    	  process(clk)
        begin
           if ram(address)/=x"00" then
              dout_buf <= ram(address);
           end if;
        end if;
        end process;
        dout <= dout_buf;
        end rtl;
    you better keep ram inference clean.
    use your same extra logic on dout instead (making it internal readable signal first)
    --- Quote Start ---
    --- Quote End ---
    how can i do that ???
    plz ,plz kaz there isn't any one help me except you
    hi sorry to bump an old thread but i had a question regarding the entity..
    port(
    clk : in std_logic;
    end entity;
    why := x"0F"; in this line
    and := 5; in the following
    thanks in advance
    Those are default assignment - if they are left unconnected when the entity is instantiated, they will be assigned those default values instead of being left open.
    Okay thanks for the reply. so similar to trigraph[0], trigraph[1]------trigraph[7] = 0x0F; in C code ? but why this init value? and not 0x0E or any other value. ?
    Hi again im tyring to add the sorting algorithm to my IP Catalog in Qsys, but get some errors regarding burstcount,readdatavalid and waitrequest. Also Clock and reset must be associated with interface. Being new to FPGA and the Altera environment i cant seem to locate where to change this. Any help would be appreciated.
    https://www.alteraforum.com/forum/attachment.php?attachmentid=10772
