12 years agosorter in vhdl
hi every one i want avhdl code to sort integer input ascending if i have an array such as 1,8,9,7,2 the out put will be such as 1,2,7,8,9 i search a lot but didn't find any code that he...
12 years agoor that modification is right
i hope you advise melibrary ieee;
use ieee.std_logic_1164.all;
use IEEE.numeric_std.all;
entity bubblesort is
port(
clk : in std_logic;
we : in std_logic := '1';
trigraph : in std_logic_vector(7 downto 0) := x"0F";
duration : in integer range 0 to 1023 := 5;
read : in std_logic := '0';
dout : out std_logic_vector(7 downto 0)
end entity;
architecture rtl of bubblesort is
signal address, rd_addr : integer range 0 to 1023 := 0;
signal trigraph_d : std_logic_vector(7 downto 0);
signal we_d : std_logic := '0';
signal dout_buf : std_logic_vector(7 downto 0) := x"ff";
type mem is array(0 to 1023) of std_logic_vector(7 downto 0);
signal ram : mem := ((others=> (others=>'0')));
begin
--infer ram
process(clk)
begin
if(rising_edge(clk)) then
dout <= ram(address);
if(we_d = '1') then
ram(address) <= trigraph_d;
end if;
end if;
end process;
process(clk)
begin
if rising_edge(clk) then
we_d <= we;
trigraph_d <= trigraph;
if read = '1' then
if rd_addr < 1023 then
rd_addr <= rd_addr + 1;
end if;
end if;
if read = '0' then
address <= duration;
else
address <= rd_addr;
end if;
end if;
end process;
--discard zeros values
process(clk)
begin
if ram(address)/=x"00" then
dout_buf <= ram(address);
end if;
end if;
end process;
dout <= dout_buf;
end rtl;
