12 years agosorter in vhdl
hi every one i want avhdl code to sort integer input ascending if i have an array such as 1,8,9,7,2 the out put will be such as 1,2,7,8,9 i search a lot but didn't find any code that he...
12 years agoI gave you a Guide and left details for you to manage. It is not in your interest to hand you a finished work.
However, this time I will correct my latency issue, see code below). You can do a further modification if you want to get rid of zero data and interrupted read by reading into two further rams. one for code and one for duration, both rams addressed by counter that increments only if non zero data arrives... then finally read out both rams from 0 to count value.
library ieee;
use ieee.std_logic_1164.all;
use IEEE.numeric_std.all;
entity bubblesort is
port(
clk : in std_logic;
we : in std_logic := '1';
trigraph : in std_logic_vector(7 downto 0) := x"0F";
duration : in integer range 0 to 1023 := 5;
read : in std_logic := '0';
dout : out std_logic_vector(7 downto 0)
end entity;
architecture rtl of bubblesort is
signal address, rd_addr : integer range 0 to 1023 := 0;
signal trigraph_d : std_logic_vector(7 downto 0);
signal we_d : std_logic := '0';
type mem is array(0 to 1023) of std_logic_vector(7 downto 0);
signal ram : mem := ((others=> (others=>'0')));
begin
--infer ram
process(clk)
begin
if(rising_edge(clk)) then
dout <= ram(address);
if(we_d = '1') then
ram(address) <= trigraph_d;
end if;
end if;
end process;
process(clk)
begin
if rising_edge(clk) then
we_d <= we;
trigraph_d <= trigraph;
if read = '1' then
if rd_addr < 1023 then
rd_addr <= rd_addr + 1;
end if;
end if;
if read = '0' then
address <= duration;
else
address <= rd_addr;
end if;
end if;
end process;
end rtl;
