17 years ago
Software Settings file (STF) damaged
I have a built a project using in 'Embedded_Systems_Lab ' from http://www.nioswiki.com/embedded_systems_lab.
But when I try to create an application using this built system I get the error
"Software Settings (STF) file associated with thi project is damaged
Reason : java.net.MalformedURLException: unknown protocol: c".
How to overcome this problem?
Thanks for the solution,
    The problem is solved and I could create the project successfully.
    There was a space in the project path which was causing the error.
    Thanks!!!
    I am trying to create a new blank project using the DE1_system.ptf file created by following the steps in 'Embedded_Systems_Lab'.
    So i think there might be something wrong with the Quartus project but there were no errors and everything went well while compiling and building it.
    Hi Nishant,
    I mean, while creating project in Nios IDE.
    By the way, are you trying to create new project in Nios IDE or just reopen the existing project. I think you will not get the error if you create new blank project and copy your c source file inot it and builde the poject. Let try with it.
    Hardik Sheth
    No. I am able to create the required files .pft, .sof etc... successfully.
    Is it because of the web-edition of QuartusII?
    I tried creating a project from NiosII command shell also but getting the same error.
    - Nishant
    Is there any error you got while creating new project?
    Hardik
    Because of the error Nios_project is not created, only syslib project is created. I searched for .stf file in the project directory also but it is not present.
    Can you show me your nios project software setting file (STF)?
    You can find this stf file from <Nios IDE>\Nios_project\applicaiton.stf
    Hardik Sheth
