17 years agoSoftware Settings file (STF) damaged
Hi, I have a built a project using in 'Embedded_Systems_Lab ' from http://www.nioswiki.com/embedded_systems_lab. But when I try to create an application using this built system I get the error ...
17 years agoThe problem is solved and I could create the project successfully.
There was a space in the project path which was causing the error. Thanks!!!
