YDu00's avatar
YDu00
7 years ago
sof and pof behaves differently for Max 10
I am using 10M04 FPGA. for some of the versions of my RTL project, if I download SOF file, it works great. if I download POF, it works partially right. this happends on all 3 boards that I have.
any one know what is the potential issue this is?
  • YDu00's avatar
    YDu00
    Hi,John,
    It is functionally not working correctly.
    Now I have the following experiments that reveals the issue(FPGA start to config from CFM to Logic cells before Logic cells power up stably).
    1. after power up, I draw NCONFIG pin to low to force a re-configuration, and this fix the issue.
    2. I connect a 10UF capacitor between GND and NCONFIG pin, and this also fix the issue.
    3. As mentioned before, I change config settings from" instant ON" to "slow POR delay", and it fix the issue.
    So, based on the 3 experiments above, my conclusion is that, right after Power up, FPGA start to config from CFM to Logic cells before Logic cells powered up stably.
    Is there any other suggestions beyond my solution above?
  • JohnT_Altera's avatar
    JohnT_Altera
    May I know when you mention POF is not working then what is the issue observed? Is it the functionality is not working correctly?
    When you change the config setting, I do not think that there is changes in the netlist and it is only changing so that the Max 10 device will have a slower time to enter usermode.
  • YDu00's avatar
    YDu00
    Now I change the config device settings from "instant on" to "slow POR delay", and it fix the issue.
    Not sure if this really fix the issue, or there is netlist change due to this different setting which avoid the cornor case having the issue.
  • YDu00's avatar
    YDu00
    By the way, I am using Quartus 15.0 64-bit windows.
  • YDu00's avatar
    YDu00
    Thank you sstrell and JohnT.
    Yes, after downloading the POF, I did power down and power up and reset.
    The design is a UART receiver and CRC checker. If CRC passed, we update certain registers to the value received. if CRC failed, then we don't update the registers.
    we have 3 version of the RTL,
    1. for first version, SOF and POF works great.
    2. for 2nd version, we changed some other logic not related the UART function. and for this compile, SOF works, and POF not working.
    3. based on 2nd version. I added signal tap analyzer in the design trying to debug where the problem is. I did not change any of the RTL. for this version, SOF and POF both works well.
    So, this looks very strange to me, meaning, the 2nd version, the netlist is slightly different than the 1st or 3rd version, and this causes the POF not working.
    JohnT_Altera
    When you download POF, do you power cycle your board? May I know what is the issue that you are observing? Do you performed system reset after you power on your board?
  • sstrell's avatar
    sstrell
    It's not really possible to answer without knowing what the design is supposed to do and what happens differently between the two files. Also, where is the .pof being stored? I presume in the CFM. Can you provide more details?
    #iwork4intel
