15 years agoSimulating a VHDL array
Modelsim-Altera returns an error when I try to drive the 'x' inputs in the code below: "Error: (vsim-3455) Can force arrays only if they are one-dimensional arrays of character enums." ...
15 years agoOkay, here's my attempt at a testbench:
-- Test Bench for Gen_Mux
-- 4-6-11
library ieee;
use ieee.std_logic_1164.all;
use work.pkg_array.all;
entity test_bench is
generic (n: integer := 2);
end entity test_bench;
architecture test of test_bench is
signal x: vec_array(0 to (2**n - 1));
signal sel: integer range 0 to (2**n - 1);
signal y: std_logic_vector(7 downto 0);
begin
dut: entity work.Gen_Mux(description)
port map(
x => x,
sel => sel,
y => y);
stimulus: process is
begin
x(0) <= "10001001";
x(1) <= "00001111";
x(2) <= "11110000";
x(3) <= "10101010";
sel <= 2;
wait for 5 ns;
sel <= 0;
wait;
end process stimulus;
end test;
The code compiles without errors in Quartus 10.1 sp1. Does it look correct? Any suggestions? Also, I have included this file in Assignments > Settings > EDA Tool Settings > Simulation > NativeLink Settings > Compile Test Bench..., but nothing happens when I run ModelSim-Altera. Is there another setting that I am missing somewhere? Thanks, Steve
