mmare6's avatar
mmare6
7 years ago
Simulate ADC MAX10
in several tutorials and examples the reset path is connected as in the picture.
However, it doesn't work for me. if I set the reset to "true" PLL simulation does not start. If I set the reset to "false", the PLL simulation starts, however the ADC simulation does not work.
The simulation works if I disconnect PLL Reset Signal from ADC Reset Signal (platform designer), And next I assign this signal in test-bench file (with negation)
assign modular_adc_0_reset_sink_reset_n=!reset_reset_n;
My test-bench file looks like this:
initial
begin
	reset_reset_n =1;
	clk_clk =0;
	#100000
	modular_adc_0_command_valid =1;
	modular_adc_0_command_channel=0;
	reset_reset_n =0;
end
always
#50000 clk_clk =!clk_clk;
endmodule
the simulation works, but in the downloaded examples are different. Now I don't know what is correct ??
  • Can we arrange a skype call meeting to further understand the issue?
  • mmare6's avatar
    mmare6
    I found that the platform designer generates such code
    adcSys_modular_adc_0 modular_adc_0 (
    		.clock_clk              (clk_clk),                              //          clock.clk
    		.reset_sink_reset_n     (~rst_controller_reset_out_reset),   // this reset negation
    Platform Designer generate code with reset negation in ADC instance. Is possible edit this??
    When I manually remove "~" compiler generate error:
    Error (10228): Verilog HDL error at adcsys.v(6): module "adcSys" cannot be declared more than once
