17 years agosimplest way to start using triple speed ethernet under NIOS WITHOUT RTOS
Good day!
I am beginner at NIOS programming thats why I need your help. I need to create light SNMP manager under NIOS. Maybe some one see any examples of projects that used Triple speed ethernet megacore on NIOS without RTOS and Niche stack (or I am wrong about it and without Niche this MAC doesnt work at all) under NIOS EDS 9.0? Or maybe you will tel me another way? Now I tryed to do all with TSE API but even including triple_speed_ethernet_iniche.h to init MAC not work without using RTOS make -s all includes Compiling main.c... ../main.c:1:42: triple_speed_ethernet_iniche.h: No such file or directory make: *** [obj/main.o] Error 1 Build completed in 14.796 seconds triple_speed_ethernet_iniche.h in project properties but that doesn't help me too... I tryed to include path to project properties but that doesn't help me too. PS At this moment I just want to get packet from network without using Niche stack.1 Reply
Running the Interniche TCP/IP stack without the RTOS is called "Superloop mode", and while it is not supported by Altera, you can find some information here (http://www.nioswiki.com/exampledesigns/superloopsimplesocketserverplus).
Running without the Niche stack will require a lot more work, you would have to write your own stack from scratch.
