17 years agosimplest way to start using triple speed ethernet under NIOS WITHOUT RTOS
Good day! I am beginner at NIOS programming thats why I need your help. I need to create light SNMP manager under NIOS. Maybe some one see any examples of projects that used Triple speed ethernet ...
17 years agoRunning the Interniche TCP/IP stack without the RTOS is called "Superloop mode", and while it is not supported by Altera, you can find some information here (http://www.nioswiki.com/exampledesigns/superloopsimplesocketserverplus).
Running without the Niche stack will require a lot more work, you would have to write your own stack from scratch.
