17 years agoSimple RAM test, with unexplained clock delay?
I'm creating a scanline buffer, which will eventually be filled by a fast clock, and which will be read by a slower clock (VGA clock). But before I'm there yet, I decided to do a simple RAM test. I have a RAM module (the scanline buffer), consisting of 640 words of 12 bits. For this test, I am constantly reading bit0 of the first 8 words, and combining these 8 bits to the 8bit led buffer, which feeds LEDG, so I can see this buffer visually. I'm also using switches to drive the write enable, write address and write data. The problem now is that when I write a 1 to address 0, LEDG[1] will light up, while I expected LEDG[0] to light up :(. It seems like there is a single clock delay which I can't explain. Maybe someone can help me understand why this happens? I've attached my Verilog test files to this thread so you can see for yourself.2 Replies
Ah that explains it. Thank you.
There is a one clock latency on reading the RAM. The read address is latched on one clock with the read data being available on the following clock:
Change this:
to this:always @(posedge clk) begin if (reset) begin rdx = 0; end else begin ledbuffer = rddata; rdx = rdx+3'b1; end endreg rdx_r; always @(posedge clk or posedge reset) if (reset) begin rdx <= 3'd0; rdx_r <= 3'd0; end else begin ledbuffer <= rddata; rdx <= rdx+3'd1; rdx_r <= rdx; end
