simple question on nios2 IDE
hi,
I have received a project (quartus with nios) from a coworker and I just wanted to open the software part in nios2 IDE 9.0. I can open que qpf project with vhdl and schematics very easily with quartus. I can open the sopc builder in quartus. I can open the *.c and *.h files in nios2 IDE 9.0, but I can't open the project!!! So I can't see the build options and I can't build it. Does anyone have any idea to do that? thank you.15 Replies
I have created a new project, now I can build but I no longer have the options in the "system library" which is now the "BSP editor". So when I build my project, because I haven't the good option, the project is too big for the memory. it is not the solution I was looking for.
have files or folder "hidden" option enabled?
NB : I work with Quartus + nios II IDE 9.0 sp2 I had a similar problem, my workaround is : - to create a new empty project - to recreate syslib from ptf file - to copy sources *.c *.h to this new project. i eared that nios ii ide will be discontinued ? - Altera_Forum
here I am again, I have installed the new Nios2 9.1 version, and I try again to reopen my project. What I have done : - work on my project with nios2 9.0 - uninstall quartus 9.0 and nios2 9.0 - install quartus 9.1 and nios2 9.1 - import both syslib and main projects. And I have the same issue. Nothing works at all! Can't altera create a "Open Project" option to make it easier? I have no spaces in my path. the project is the very same as the one in the 9.0 version. I don't know what to do now... - Altera_Forum
well...
I don't know what I had done but I should have made something wrong in the first place because now, everything works. I have erase the whole project and taken the safe project from the zipped file, and there isn't any error left. I certainly changed a file without noticing it. Thank you Parrado for your help, and sorry for not having sawn that before. - Altera_Forum
Each project has his own workspace at the project folder importing should be enough. Could you post:
* Nios II IDE projects * .ptf file (it's into Quartus project folder) - Altera_Forum
no "readonly" options,
the building doesn't create any file... I don't understand what is happening. Maybe the workspace has to be set to something? - Altera_Forum
doesn't building process generate .o files? have files or folder "only reading" optionn enabled?
I have _ and - but no space.
PTF file is used by system library project, as You could import both projects there is no problem. Please, be sure your path doesn't have spaces.
I have already done that. I have retested and rechecked. but the build still doesn't do anything...
I have a ptf file but I don't know how to specify the project to use it.
