12 years agoSignalTap II sample clock timing violation
I have a system running at 250Mhz and I want to sample certain internal signals by using signaltap ii. I learnt that I should use at least 500Mhz sample clock (double the working clock freq.) in orde...
12 years ago --- Quote Start --- SignalTap should be running on the same clock as the signals you're sampling, in which case it's fully synchronous transfers and there's no need to oversample. (I've never heard of oversampling with SignalTap when grabbing from other, asynchronous, clock domains, but imagine it could work. Still hard to read the data since it's not just what you capture, but how it aligns with other signals, which you can't fully count on...) --- Quote End --- Oh..Does that mean I can use main working clock directly as the sampling clock?
