JC_arlen
3 years agosignal tap invalid data received
I have an ALTERA USB Blaster, some year ago i used it with a Cyclone IV without any problem using Signal Tap .
Now i am trying to use the same ALTERA USB Blaster with EP4CE10E22 , it wor...
RichardT_altera
3 years agoCAUSE: You tried to run the Signal Tap Logic Analyzer, but the communications cable or circuit board is disconnected, or you made changes to the circuit board. As a result, the Signal Tap Logic Analyzer cannot acquire data.
ACTION: Make sure the communications cable and circuit board are connected to your system, and re-attempt to run the Signal Tap Logic Analyzer.
Most likely is connection issue or you might have made changes to the signal tap and need to recompile.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
