17 years agoSetup/Hold time margin calculation for FPGA
Hi, In my design, I used cyclone II FPGA. I just want to calculate the setup/hold time margin for some interfaces (like PCI 32/66). For this calculation, I need the setup/hold time of the signa...
17 years agoThanks KAZ,
I could understand that, I can use the same formula as like doing with other ICs. But my problem is, I have to get the timing parameter (setup/hold time) from FPGA end. But in their datasheet, they gave it for IOE and LE_FF. I can't get how to use this values for my margin calculation. In stead of doing with tool, I tried to calculate by formulas. My question is, How to derive the FPGA signal's setup/hold time from the timing parameters (Tsu/Th/Tco for IOE and LE_FF) as given in their datasheet ? http://www.altera.com/literature/hb/cyc2/cyc2_cii51005.pdf Pg - 19 Regards, -V
