9 years agoset_net_delay overwrite
Hello!
I am using the avalon_st_clock_crosser IP in my Design which has a net_delay constraint of 2ns. This is defined in the .../ip/altera/avalon_st/altera_avalon_st_handshake_clock_crosser folder. Unfortunately this constraint can't be met in all cases by some few ten pico seconds, which is not really a problem itself. I would like to modify the existing constrain (within my design) to get rid of the violation messages. Other timing exceptions like set_max_delay or set_max_skew have a precedence that the last assignments overwrite earlier assignments. "set_net_delay" seems to behave different.
set_net_delay -from X -to Y 2.001
set_net_delay -from X -to Y 2.002
set_net_delay -from X -to Y 2.003
.. results in having three additional timing violations instead of having only the one with the last setting. Some (partially ugly) workarounds i thought of: - changing the IP in the intel component folder
- copying the IP to my Project folder, change the IP there,
- disable automatic test of net delay violations and live with the violations with the risk of overlook some real violation, additional effort in manual verification
