16 years agoSending output pin to input pin in the other .bdf file
Hi All; How can I send a output pin in the circuit to a input pin in the other file altera Best regards
16 years ago --- Quote Start --- Thank you for your reply. But, how can I send the output pin to other .bdf file without a symbol file or the third .bdf file. best regards --- Quote End --- Hi, let's try to clarify what you would like to achieve. I assume you have one BDF with , let say an output A. You will use this output A as input A in an other BDF. Right ? As far as I know the only way to do this is described by "makontrack". The "connection" between the BDF's is described by the design hierachy. The lower level BDF's are always represented by symbols in higher levels. Kind regards GPK
