16 years agoSending output pin to input pin in the other .bdf file
Hi All; How can I send a output pin in the circuit to a input pin in the other file altera Best regards
16 years agoWell, there is this standard procedure.
Let me explain with an example. Suppose I have 2 circuits: a counter ( in any form: counter.v/counter.vhd/counter.bdf) & a comparator (again in any form comparator.v/comparator.vhd/comparator.bdf). Now I wish to supply the output of the counter as a ramp input to the comparator, in order to generate a PWM. procedure: 1) Open the counter file in Quartus II. 2) Go to file -> create/update -> create symbol files for current file ( this command will compile your counter circuit & save a symbol file called counter.bsf in your project directory) 3) Do the same thing with the comparator file. 4) Now, create a new BDF file, call it pwm_generation.bdf 5) Double-click anywhere inside to bring-up the symbol window. There click the '+' sign before 'project' where you will find your counter & comparator. 6) Just bring them together on this new block diagram file, and do the required input-to-output wiring ! That's it. ( You may also edit & customize the individual counter.bsf & comparator.bsf symbols to suit your connection routing )
