9 years ago
Send data from FPGA to computer using a USB to TTL
Hi, i'm a newbie using FPGAs and i'm trying to send data from FPGA to computer using a USB to TTL adapter but so far the only thing i can send is just one bit, i can see it on putty, is just trash because i need 8 bits to send understandable things, however what i want is to send 8 bits at the same time but i can't do it. Any suggestion?
    I said write an UART module, means Verilog or VHDL code for it, example below.
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.numeric_std.all;
    entity TxUnit is
      generic (
          CONSTANT BAUD 	: INTEGER := 26 -- 921 kBaud @ 24 MHz Clk
      port (
         	Clk    	: in  Std_Logic;  -- Sample CLK
         	Reset  	: in  Std_Logic := '0';  -- Reset input
         	Enable 	: in  Std_Logic := '1';  -- Enable input
         	DataI  	: in	Std_Logic_Vector(7 downto 0); -- Send data
         	TxStrt 	: in 	Std_Logic;  -- Send command
    	clkout	: buffer Std_Logic;
    	TxRdy  	: out Std_Logic;
         	TxD    	: out Std_Logic);  -- UART data output
    end entity;
    architecture RTL of TxUnit is
      signal SReg    	: Std_Logic_Vector(7 downto 0); -- Byte send register
      signal BitPos   : INTEGER range 0 to 11;   -- Position of the bit in the byteframe
      signal clkcount : INTEGER range 0 to BAUD - 1;
    begin
    -- Tx Process
    	TxProc : process(Clk,Reset,Enable)
      	begin
         	if Reset = '1' then -- Reset
            	BitPos <= 0;
     			TxD <= '1';
         	elsif Enable = '1' and Rising_Edge(Clk) then
    			if clkcount < BAUD-1 then
    				clkcount <= clkcount + 1;
    				clkout <= '0';
    			else
    				clkout <= '1';
    				clkcount <= 0;
            	end if;
    			case BitPos is
    				when 0 =>
    					if TxStrt = '1' then -- Start
    						BitPos <= 1;
    						SReg <= DataI(7 downto 0);
    					end if;
    				when 11 =>
    					if clkout = '1' then
    						BitPos <= 0;
    					end if;
    				when others =>
    						BitPos <= BitPos + 1;
    					end if;
    			end case;
    			case BitPos is
    				when 0 | 1 =>
    					TxD <= '1';  -- Idle position
    				when 2 =>
    					TxD <= '0';  -- Start bit
    				when others =>
    					TxD <= SReg(0);
    						SReg <= '1' & SReg(7 downto 1); -- Serialization LSB first
    					end if;
    			end case;
         	end if;				-- RisindEdge(clk)
      end process;
      TxRdy <= 	'1' 	WHEN BitPos = 0  ELSE
    				'0';
     end RTL;
    The TX pin of that header has UART or i need to use an UART that after connects to the TX pin?
    Serial interface sends always 8 bits (or 7 bits in special configurations) at once. Putty can't display a single bit. There might be a problem of non-matching baud rates, or non-printable ASCII codes send to the terminal program.
    Arduino TX is FPGA pin Arduino_IO6, if I understand right. How are you driving it? You would write an UART module generating start bit, 8 data bits and stop bit with correct baud rate.
    Hi, thanks for reply, i think it's the USB-to-serial because i sent data through the TX pin on the arduino header of the DEO-nano-SoC (cyclone V).
    Lack of information. Are you talking about an USB-to-TTL parallel interface like FTDI FT245 or an USB-to-serial interface like FT232? Both can be used but need different interface on the FPGA side.
