9 years agoSend data from FPGA to computer using a USB to TTL
Hi, i'm a newbie using FPGAs and i'm trying to send data from FPGA to computer using a USB to TTL adapter but so far the only thing i can send is just one bit, i can see it on putty, is just trash be...
9 years agoI said write an UART module, means Verilog or VHDL code for it, example below.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity TxUnit is
generic (
CONSTANT BAUD : INTEGER := 26 -- 921 kBaud @ 24 MHz Clk
port (
Clk : in Std_Logic; -- Sample CLK
Reset : in Std_Logic := '0'; -- Reset input
Enable : in Std_Logic := '1'; -- Enable input
DataI : in Std_Logic_Vector(7 downto 0); -- Send data
TxStrt : in Std_Logic; -- Send command
clkout : buffer Std_Logic;
TxRdy : out Std_Logic;
TxD : out Std_Logic); -- UART data output
end entity;
architecture RTL of TxUnit is
signal SReg : Std_Logic_Vector(7 downto 0); -- Byte send register
signal BitPos : INTEGER range 0 to 11; -- Position of the bit in the byteframe
signal clkcount : INTEGER range 0 to BAUD - 1;
begin
-- Tx Process
TxProc : process(Clk,Reset,Enable)
begin
if Reset = '1' then -- Reset
BitPos <= 0;
TxD <= '1';
elsif Enable = '1' and Rising_Edge(Clk) then
if clkcount < BAUD-1 then
clkcount <= clkcount + 1;
clkout <= '0';
else
clkout <= '1';
clkcount <= 0;
end if;
case BitPos is
when 0 =>
if TxStrt = '1' then -- Start
BitPos <= 1;
SReg <= DataI(7 downto 0);
end if;
when 11 =>
if clkout = '1' then
BitPos <= 0;
end if;
when others =>
BitPos <= BitPos + 1;
end if;
end case;
case BitPos is
when 0 | 1 =>
TxD <= '1'; -- Idle position
when 2 =>
TxD <= '0'; -- Start bit
when others =>
TxD <= SReg(0);
SReg <= '1' & SReg(7 downto 1); -- Serialization LSB first
end if;
end case;
end if; -- RisindEdge(clk)
end process;
TxRdy <= '1' WHEN BitPos = 0 ELSE
'0';
end RTL;
