Vic3DexeOccasional Contributor3 years agoSDC constrains for async static RAM I have async static RAM with 10 ns access time. I try to read data from it in such a way, that address formed in one register, then data latched to another, both have the same clock 50 MHz (20 ns)....Show More
NurinaRegular Contributor3 years agoHi,Could you try put your data_reg at the I/O? This would reduce the delay.Regards,Nurina
Vic3DexeOccasional Contributor to Nurina3 years ago@Nurina wrote: Could you try put your data_reg at the I/O? This would reduce the delay. I will try, thx.
Recent DiscussionsMAX10 FPGA IOs not entering Tri-state (Hi-Z)To INTEL - Request for Compliance Data from your customerPower-Down Sequence Requirements for the Agilex 7 F-Series(2x F-Tile) Devicesabout cyclone 10gx transceiverwriting a word to cfm1 using on chip flash ip on max10
