15 years agoschematics LED connection
what is difference when we connect resister b/w fpga and led,
And Fpga is directly connected with led then pull down? Regards, shahul7 Replies
Mostly, people are operating LEDs with active low FPGA outputs and anode connected to 3.3V for the said reason.
Before configuration all the pins have a weak pull-up, so this can explain why you see them glowing. It should be a lot dimmer than with an output pin at logical '1' though.
Hi Daixiwen,
why i ask this question is in our FPGA we have 8 leds connected as the top schematics shown in that figure.At the time of power ON all led glow. I don't no why this leds are glowing.it should be in off state. Regards, shahul - Altera_Forum
I don't understand your question... putting the resistors before or after the leds doesn't change anything, as in both cases they are in series with the leds.
But with 10k I don't think that you'll see a lot. Just check the LED datasheet for the recommended current and standard forward voltage, and determine the nominal value for your resistors. - Altera_Forum
please reply to the above question?
use resister can reduce the current and the brightness of the led.
