15 years agoschematics LED connection
what is difference when we connect resister b/w fpga and led, And Fpga is directly connected with led then pull down? Regards, shahul
15 years agoI don't understand your question... putting the resistors before or after the leds doesn't change anything, as in both cases they are in series with the leds.
But with 10k I don't think that you'll see a lot. Just check the LED datasheet for the recommended current and standard forward voltage, and determine the nominal value for your resistors.
