rsu_client failing to write to slot
- 15 days ago
Dear all,
I had the same issue. Here is my solution for future reference.
I can reproduce this using the following script:
for i in {1..2000}; do
echo "Iteration $i"
rsu_client --erase 0 || break
rsu_client --add update.rpd --slot 0 || break
done
Using this script the problem occurs every 508th iteration on my system. Once in the error state, I can only get out of it by flashing the .jic file. Running the commands in U-Boot did not work for me.
In iteration 1-507 the rsu_client performs a "write" to update the CPB. In the 508th iteration it performs an additional "erase" before the "write". This is why it occurs so infrequently.
For me the fix was to increase the size of the SPT and CPB partitions to the erase size of my QSPI flash (64KiB) in the programming file generator file (.pfg).
Kind Regards,
Eric Opitz
