12 years agoRetrieving usercode from binary configuration image
Hello, there have been various discussions about the raw binary file format, solutions for the basically simple problem of retrieving the usercode have been already posted. http://www.alterafo...
12 years agoHello Dave,
that's a reasonable method if a configuration controller is involved, e.g. multiple FPGAs configured from a single flash memory. I'm targetting to "minimal" systems with programmable part comprised of one FPGA and a serial flash. I have the RSU running now with a pof check demanding a specific usercode target field. It turned out that (at least for cyclone III) the RSU controller is reading in the rbf header part, 40 data bytes and a CRC16 or checksum. The usercode is placed in byte offset 8 to 39, bit 0. The RSU controller checks the CRC, so you can enforce a pof error if you don't accept the usercode. Best wishes, Frank
