9 years agoreset sync design logic
I have a question regarding reset sync logic .
first of all what I understood about requirement of reset synchronization in design : - Reset will be asynchronous in nature. - It is not an issue if reset assertion in design will not be on active edge. - But when de-asserting reset at that time it must be on active edge of clock. - If de-assertion is asynchronous in nature then it may case design output to stuck into metastable-state - So to prevent it reset synchronize is used. ( I would request to all member to clarify me about need of reset synchronize if i understood something wrong !!! ) - When I google about how to design reset synchronize module I just confused with the way they have synchronize reset with clock. //================================================================================================================================== // reset synchronize logic snippet I found from website //================================================================================================================================== module reset_synchronize ( input clock_i, input resetn_i, output sync_resetn_o ); logic resetn_f1; logic resetn_f2; assign sync_resetn_o = resetn_f2; always_ff @(posedge clock_i or negedge resetn_i) begin if(~resetn_i) begin resetn_f1 <= 0; resetn_f2 <= 0; end else begin resetn_f1 <= 1'b1; resetn_f2 <= resetn_f1; end end endmodule //============================================================================================================== // what I observed from above snippet & my question //============================================================================================================== - have used two flip-flops ( no idea for what they have used second flip-flop as my reset will sync only need 1 flip-flop ) - when reset_n is there will be keeping "resetn_f1" & "resetn_f2" zero ( I am okey with this !! ) - when reset_n = 1 then will be giving "resetn_f1 == 1" & "resetn_f2 = resetn_f1" Q1 : whay they have used "resetn_f2" as with simple "resetn_f1" also I can have de-assertion of reset_n on clock edge.11 Replies
--- Quote Start --- @ Kaz, According to me, we must reset second register also. Consider the case when clock has been lost due to some issue and meantime, we need to reset our design. In this case, if we do not use reset for second register, our design will not get reset. So, by using reset for second register, we ensure that 'asynchronous' assertion benefit of reset ( design can be reset even in the absence of clock ) is preserved. Feel free to share your thought. Thank you, Bhaumik --- Quote End --- That makes perfect sense. It also explains why reset synchroniser is safer than just passing reset through D input(data synchroniser) Thanks for sharing
