14 years ago
Remote update controller issue
Hi everyone,
I'm using the remote update controller (cyclone III) on my Cyclone IV GX dev board with a EPCS128 flash memory.
I wish to have two firmwares in my EPCS (factory and application).
Actually, I placed the firmware like this in the EPCS:
0x000000 Factory image (hw0 + sw0)
0x440000 Application image (hw1 + sw1)
(I'm not using the flash programmer to load the image in flash memory)
The nios II boots correctly on the factory image when I start the board.
But when I try to reconfig the FPGA with the application image using the remote update controller, the Factory image is loaded...
I write 0x110000 to the remote update controller, then start the reconfig for loading the application image. Is this address correct?
I think my problem comes when I'm creating the application image.
Here is my script to create the .flash:
--- Quote Start ---
java -jar C:\altera\11.0\nios2eds\bin\sof2flash.jar --epcs --input="..\..\2Dcam.sof" --output="2Dcam_sof.flash" --verbose
java -jar C:\altera\11.0\nios2eds\bin\elf2flash.jar --epcs --after="2Dcam_sof.flash" --input="..\2DCam\2DCam.elf" --output="2DCam_elf.flash" --offset 0
rem merge the two files
copy /b /y 2Dcam_sof.flash+2DCam_elf.flash 2DCam.flash
--- Quote End ---
I create factory and application image (.flash) with this script. And load the factory image at address 0x000000 and the application at address 0x440000 in EPCS.
Do I have to make something different for the application image, because her address is not 0x000000?
Has anyone the same problem?
Best regards
