13 years ago
relative path in a do file
hello
i am a beginner in modelsim
i want to use relative path in do file but it doesn't work
my os is windows xp
my relative path is :
vcom -work Work_Project ../../SRC/A_Interface.vhd
error:
Failed to open design unit file "../../SRC/A_Interface.vhd" in read mode.
how can i do this?
thanks alot.
    --- Quote Start ---
    when checked the Modelsim reference manual,
    i found the following commands for the question i posted
    config list -strobeperiod {100 ns} -strobestart {0 ns} -usestrobe 1
    add list -notrigger clk -window mylist a b c d
    write list mylist.save;
    I will check if this can solve my issue ,Thanks
    --- Quote End ---
    Dear all
    With above commands i am able to create the list file
    But problem came when trying to generate multiple list files
    I am able to create two list files but the data will only be updated in only one list file
    The window generated with view list -new highlighted below
    The commands i used are as follows :
    set wind1 [view list -title wind1]
    add list -notrigger -label a -window $wind1 simulationpath
    set wind2 [view list -new -title wind2]
    add list -notrigger -label b -window $wind2 simulation path
    run 50 us
    write list -window $wind1 wind1.list
    write list -window $wind2 wind2.list
    Please let me know the reason behind why only one list file is updated
    Thanks in advance for all your support
