Recovery errors with Time Quest Timing Analyser
I would like to know how to remove the Recovery errors in a design in which i cannot change the RTL code(as design not done by me)
I have read the RSYNC manual "Understanding Recovery and Removal Analysis" Thanks for clearly stating the basics Some suggestions made in the document as follows a) if driving a global and the reset register is not placed near the global driver, then the user should add a location assignment to that register, forcing it near the global. How can i achieve this in the Quartus tool please clearly explain me b) if the asynchronous reset fails timing and does not use global routing, try assigning it to use a global(in the assignment editor, make a global = on assignment to the source register driving the asynchronous signal)In the assignmenent editor i see the Reset pin and if set it as Global i see that the pin number assigned already disappears and i am unable to assign the pin number again Please explain me how can i make the pin as global = ON or OFF Regards M Kalyansrinivas
I wouldn't remove reset per block but per node as I go through design development. Each module has its reset input in case needed. Statements can be put there and commented in/out readily.
Still dangerous unless you really know what you're doing. As an example, there may be a large block that is purely datapath, but inside is a 1:2 demux and 2:1 mux that is used to send data in/out of a section that is double-clocked. The select for these two are run by a toggle flip-flop. Seems innocent enough, but if the two registers come out of reset at different times, the design won't work. 99% of the time that isn't a problem(and if the reset is on a global, it won't occur 99.99% of the time). This is the type of thing that gets missed because the user doesn't think of it as "control logic".
If the reset is on a global, I don't see any reason not to reset everything. I think you're recommendation works when truly needed, but most large designs still don't have any recovery problems and resetting everything doesn't hurt them. That being said, there are potentially cases where not resetting the datapath could help, but you need to know what you're doing since there is no analysis tool that will tell you what is and is not safe to take off the reset. - Altera_Forum
Hi Rysc,
Reseting everything is safe luxury that can't be afforded in today's large designs. You need to remove reset from where it is not needed for sure. Reseting say dsp data path is completely meaningless in a system that "washes off" initial zeros and other filtering responses till they settle. It is the control logic that must have reset, state machines, enables ...etc. Surely these need not be tampered with. Hi Kalyansirinvasim, No I don't mean that, you should do that for the asynchronous anyway. I meant you can apply reset after clk edge instead of before... One other way (for exams) to get rid of all the trouble is to not register the reset at all, then there will be no paths to report and you could get a clean report (but fake), though this cheating but many designers are not aware of it. - Altera_Forum
Just to be sure, did you look at recovery/removal in this document:
http://www.alterawiki.com/wiki/timequest_user_guide (I wrote another one called Understand Recovery/Removal, but this one is more up to date.) My initial question is about how the system works. TimeQuest analyzes asynch reset signals with synchronous timing, which is a good thing. But if the signal is coming in from a truly asynchronous source, say a pushbutton or out of a device on another clock domain, there is no reason to have TQ try to time it, since it's not a real analysis. You would need to enter an asynchronous assert/synchronous de-assert circuit. - Synchronizing it with a double-flop synchronizer could also be used to get it into the main clock domain, but you lose the asynchronous assert capabilities. Quite often that is not a big deal. - I do not fully agree with Kaz's comment. I get the point and agree in principle, but in practice it has the user constantly going "does this need a reset?". There is no easy way to test if the user's answer is correct either. I find it safer to just reset everything. I also don't think this hurts timing, as usually right by the data path that wouldn't have a reset is some control logic that does, so if it can meet timing to the control logic, it would have met timing to the data path. The only major advantage is if the reset is using local routing, it would save a little bit, but that's usually not too big of a deal. I just think the risk of not adding a reset to the wrong signal and the extra engineering time figuring it out are not worth it. (I'm working with someone who has a reset failure right now, where one build occasionally fails out of reset. Most other images of that build happen to meet timing. It's a complete nightmare to debug and prove why it's occurring.) - Altera_Forum
--- Quote Start --- Alternatively move reset to synchronous but this only moves the burden away from recovery/removal to tSU/tH but may work --- Quote End --- Do you mean "To synchronize the asynchronous reset signal using a double flop synchronizer" I have attached a image file of what i understand by your saying - Altera_Forum
By far the most effective way to avoid these timing errors is to remove its burden on timing. Reseting a mass of registers unnecessarily should be avoided. Paths like data for example usually need no resets.
Alternatively move reset to synchronous but this only moves the burden away from recovery/removal to tSU/tH but may work - Altera_Forum
Hi Rysc
It is a reset Strobe signal , I feel its an asynchronous signal The Time Quest shows that there is a slack on this signal (In Recovery issues of Timing Analyzer) when i used the "report_timing" on this violation it reported me as follows report_timing -from_clock {inst_PLL_Clk_ADC|altpll_component|auto_generated|pll1|clk[1] } -to_clock { inst_PLL_Clk_ADC|altpll_component|auto_generated|pll1|clk[1] } -from {If_GetData_GX_ADC:inst_If_GetData_GX_ADC|GestionReset:inst_GestionReset|Rst_RecupData_n_o} -to {If_GetData_GX_ADC:inst_If_GetData_GX_ADC|RecupData:inst_RecupData|Fifo_Streaming:inst_Fifo_Streaming|dcfifo:dcfifo_component|dcfifo_b2i1:auto_generated|altsyncram_9h31:fifo_ram|ram_block5a0~portb_address_reg0} -recovery -npaths 10 -detail full_path -panel_name {Report Timing} Regarding the Assignment editor i am doing this for recovery removal(as you suggested) -- Please see Rst_ADC_Board_o pin J10 Thank you for the help - Altera_Forum
Is the signal synchronous to the registers it drives? Meaning, if you do recovery/removal analysis on it and look at the relationships, does that match the clocking in hardware? If it's truly coming in from an asynchronous source, then you should cut timing on it, as there's no point in trying to meet timing requirements that aren't real.
If it is a real requirement, is it on a global or not? You should see clkctrl in the data path if it's on a global. It will also be listed in the Global Signals report. As for the Assignment Editor, you can make multiple assignments to the node. I'm not really sure what problem you're seeing.
