14 years agoRecovery errors with Time Quest Timing Analyser
I would like to know how to remove the Recovery errors in a design in which i cannot change the RTL code(as design not done by me) I have read the RSYNC manual "Understanding Recovery and Remov...
14 years agoHi Rysc
It is a reset Strobe signal , I feel its an asynchronous signal The Time Quest shows that there is a slack on this signal (In Recovery issues of Timing Analyzer) when i used the "report_timing" on this violation it reported me as follows report_timing -from_clock {inst_PLL_Clk_ADC|altpll_component|auto_generated|pll1|clk[1] } -to_clock { inst_PLL_Clk_ADC|altpll_component|auto_generated|pll1|clk[1] } -from {If_GetData_GX_ADC:inst_If_GetData_GX_ADC|GestionReset:inst_GestionReset|Rst_RecupData_n_o} -to {If_GetData_GX_ADC:inst_If_GetData_GX_ADC|RecupData:inst_RecupData|Fifo_Streaming:inst_Fifo_Streaming|dcfifo:dcfifo_component|dcfifo_b2i1:auto_generated|altsyncram_9h31:fifo_ram|ram_block5a0~portb_address_reg0} -recovery -npaths 10 -detail full_path -panel_name {Report Timing} Regarding the Assignment editor i am doing this for recovery removal(as you suggested) -- Please see Rst_ADC_Board_o pin J10 Thank you for the help
