16 years agoRealization MFM de/en-Coder via MAXII
Hello @ All, I'm new here and I hope that someone can help me concerning matter above. Background: I work almost honorary in my spare time for the computer museum in Munich and my goal is to...
16 years ago62,5uSec = 16kHz clock
the period is 10 times the clock so you need a clock or an clock enable that is 1 every 62,5uSec verilog HDL reg [3:0] counter; always @ ( posedge my16khzclock ) if ( counter === 4'd0 ) counter == 4'd9; // this reload the counter else counter <= counter - d'd1; now you have a counter that counts down from 9 to 0 and then reloads to 9 again. that is your period of 625uSec, assuming you have a correct clock. now the output signal, that could be a register or combinatorical wire mypulse; assign mypulse = !counter; or reg mypulse; always @ ( posedge my16khzclock ) if ( counter === 4'd0 ) mypulse <= 1'b1; else mypulse <= 1'b0; now mypulse should be 1 for a single my16khzclock cycle every 10 cycles.
