16 years agoRealization MFM de/en-Coder via MAXII
Hello @ All, I'm new here and I hope that someone can help me concerning matter above. Background: I work almost honorary in my spare time for the computer museum in Munich and my goal is to...
16 years agoReinhard,
just to give you an example how the conversion from your schematic to verilog could look like here are some few code snippets ... --- Quote Start --- --- Quote End --- Lets starts with the toggle DFF from the lower left corner --- Quote Start --- reg E128; always @ ( posedge Clk_8_2Mhz ) E128 <= ~E128; wire RLVA_SYS_1H; wire RLVA_SYS_0H; assign RLVA_SYS_1H = E128; assign RLVA_SYS_0H = ~E128; --- Quote End --- now the shift register E117 --- Quote Start --- // The shift register from Page 23 at the bottom; reg [4:0] E117; always @ ( posedge Clk_8_2Mhz or negedge RLV9_INIT_0L ) if ( !RLV9_INIT_0L ) E117 <= 4'd0; else E117[4:0] <= { E117[3:0] , RLV_MUX_DATA_H }; --- Quote End --- now the ROM E120 82S123 implemented as priority encoded wires .... well at 8.2MHz i don't worry about timing here this could also be implemented as a memory and initialised from a file but strictly implemented from original schematic without 1 clock delay a register would give it is done this way ... without propper values --- Quote Start --- wire [4:0] PROM_E120; assign PROM_E120 = ( E117 === 5'H00 ) ? 5'b00000 : ( E117 === 5'H01 ) ? 5'b00000 : ( E117 === 5'H02 ) ? 5'b00000 : ( E117 === 5'H03 ) ? 5'b00000 : ( E117 === 5'H04 ) ? 5'b00000 : ( E117 === 5'H05 ) ? 5'b00000 : ( E117 === 5'H06 ) ? 5'b00000 : ( E117 === 5'H07 ) ? 5'b00000 : ( E117 === 5'H08 ) ? 5'b00000 : ( E117 === 5'H09 ) ? 5'b00000 : ( E117 === 5'H0A ) ? 5'b00000 : ( E117 === 5'H0B ) ? 5'b00000 : ( E117 === 5'H0C ) ? 5'b00000 : ( E117 === 5'H0D ) ? 5'b00000 : ( E117 === 5'H0E ) ? 5'b00000 : ( E117 === 5'H0F ) ? 5'b00000 : ( E117 === 5'H10 ) ? 5'b00000 : ( E117 === 5'H11 ) ? 5'b00000 : ( E117 === 5'H12 ) ? 5'b00000 : ( E117 === 5'H13 ) ? 5'b00000 : ( E117 === 5'H14 ) ? 5'b00000 : ( E117 === 5'H15 ) ? 5'b00000 : ( E117 === 5'H16 ) ? 5'b00000 : ( E117 === 5'H17 ) ? 5'b00000 : ( E117 === 5'H18 ) ? 5'b00000 : ( E117 === 5'H19 ) ? 5'b00000 : ( E117 === 5'H1A ) ? 5'b00000 : ( E117 === 5'H1B ) ? 5'b00000 : ( E117 === 5'H1C ) ? 5'b00000 : ( E117 === 5'H1D ) ? 5'b00000 : ( E117 === 5'H1E ) ? 5'b00000 : 5'b00000 ; // now we assign the output bits of the PROM the names as used by the schematics wire RLVA_B0_H; wire RLVA_B1_H; wire RLVA_B2_H; wire RLVA_B3_H; wire RLVA_B4_H; assign RLVA_B0_H = PROM_E120[0]; assign RLVA_B1_H = PROM_E120[1]; assign RLVA_B2_H = PROM_E120[2]; assign RLVA_B3_H = PROM_E120[3]; assign RLVA_B4_H = PROM_E120[4]; --- Quote End --- last but not least the counter at the lower right --- Quote Start --- reg [3:0] E125; always @ ( posedge Clk_8_2Mhz or negedge RLV9_INIT_0L ) if ( !RLV9_INIT_0L ) // async nCLR E125 <= 4'd0; else if ( RLVA_SYS_0H ^ RLVA_R0_H ) // nLOAD E125 <= { RLVA_B4_H , RLVA_B3_H , RLVA_B2_H , RLVA_B0_H }; else // normal count operation E125 <= E125 + 4'd1; // again assign output bits the name of used by schematics wire RLVA_R0_H; wire RLVA_R1_H; wire RLVA_R2_H; wire RLVA_R3_H; assign RLVA_R0_H = E125[0]; assign RLVA_R1_H = E125[1]; assign RLVA_R2_H = E125[2]; assign RLVA_R3_H = E125[3]; --- Quote End ---
