DavidSmoot
1 year agoRead flash attached to Max II in Parallel Flash Configuration on legacy system
I have a customer requesting that I reverse engineer the firmware on a legacy system so he can program some older blank stock for spares. No available source code. No available schematics. The ...
WZ2
1 year agoAh, I see what you mean now. If your goal is simply to recover the binary contents of the flash, I believe the suggestion from the FAE was to use a custom IP in the CPLD to read the data out.
As for me, I would probably lean toward physically removing the flash chip and using a third-party programmer to extract its contents directly. Of course, one would need to pay attention to things like endianness conversion, if applicable.
If the flash is in a BGA package, this could be more challenging — but from what I understand, some flash programmers are capable of handling this, though it may require reballing the device before programming.
