DavidSmoot
1 year agoRead flash attached to Max II in Parallel Flash Configuration on legacy system
I have a customer requesting that I reverse engineer the firmware on a legacy system so he can program some older blank stock for spares. No available source code. No available schematics. The ...
WZ2
1 year agoHi David,
Based on your description, I guess you want to read back the contents of the Micron Flash (28F128J3), right? From my point of view, this is quite difficult:
- The "Examine" function can be used to read back the MAX II internal program, that is, the contents of the MAX II cfm/ufm.
- The PFL IP itself does not have the ability to read back the contents of the flash; possibly the ASMI IP has this ability, but I’m not sure whether MAX II supports this IP.
- If it is purely about reading back the flash, the Micron manufacturer might be able to help you better. As far as I know, if you can connect to the flash pins, they can read back the contents of the flash using flash commands.
- However, even if you read back the image from the flash, it is, in my opinion, not feasible to reverse-engineer the .sof file from that image, so restoring the internal logic layout is not possible.
WZ
