18 years agoUSB Blaster driver conflict with other FTDI kit
Hi, I am using a USB blaster (Terasic) and on the same system I need to use two Asix Presto programmers that use the same FTDI device and (apparently) drivers. The Presto devices load up and...
SparkyNZ
Contributor
6 years agoI now have the same problem. I have been using Quartus 14 without problem for quite some time. This morning I upgraded to 20.x and now I have the same problem.
I have to shut Putty down in order to download to my FPGA. What a pain.
Looks like I'm going to need a second PC to run Putty..
avib
5 years agoI'm also having the same problem of not being able to use the USB to serial together with the USB Blaster.
There is a way to workaround Programming by disconnecting the USB to serial and re-attaching it after the programming was completed, but there is no way to use SignalTap since I need the serial port connected during the debugging...
I've tried many Quartus driver versions, and the latest USB to serial driver, but it still doesn't work.
