Three 9x9 multipliers in one DSP
Sorry for the delay in responding. I overlooked this inquiry.
As I understand it, you would like to pack three 9×9 multipliers into a single DSP block. Currently, your compilation is mapping each 9×9 multiplier to a separate DSP block.
For your information, when sufficient DSP resources are available, Quartus typically assigns one DSP block per multiplier to optimize performance and simplify implementation. Packing multiple multipliers into a single DSP block is generally considered only when DSP resources are constrained.
Similar to the forum post you referenced, you may try increasing the overall DSP utilization or applying a Logic Lock region to encourage resource packing. These approaches may help Quartus select a more resource-efficient implementation.
Please let me know if you have any further questions or if you would like to share your design details for further review.
Thank you.
- inikotin9 days ago
Thank you for your answer. I made it with logic lock region. It's solved it.
- CheepinC_altera8 days ago
Thanks for your update. Glad to hear that you have resolved it. Thank you.
